Jetzt geht's aber ab hier ![]()
Cpt14
I nix versehen !!!! Andere Baustelle
Na irgendwas muß ich mal auch können ..? Deutsch geht so halbwegs, außerdem etwas Bauer -Englisch , und Baustelle -Französisch
Das ist halt das polyglotte Freemont Forum
Hallo Istvan! Üdvözölek itt a Forumban es örülök hogy a szép Magyarországról is van itt végre valaki !! Én regen itt élek és már a második Freemontot használom nagy megelégedésemre
Szia Kelly!
Köszi! Viszont miért második? Vagy az első is megvan még? Sajnos befejezték a gyártását, így én már biztos nem jutok hozzá másodikhoz.
Dear All,
I just wanted to inform everyone, that I solved my problem yesterday evening! It was absolutely easy!
Well, before I went to switch off the battery for at least 30 minutes, I said, let's take a try to update the firmware again! This idea came, because after the first update and restart the car recognized the usb again, and asked me for another update.
So I took the usb drive, put it in the car, and again it resolved that there is an update.
Notified me what version is in the car and what is on the usb. There were the same. Ok, I said YES, update.It started as normally, checking, then progressbar with copying files. But this time this progress bar finished just in some seconds, it recognized, that those files are already there.
The car asked for a new restart, then everything went fine. No PIN question! Everything works just fine!
Now, what was the point here?
Well, when I tried the update at first, I did not switch the car to RUN mode! I left it in ACC mode only. This means not all the units are under power, just a few really required!
So after the restart when the unit asked for identity data from the car, those units were offline, so it behaved like when the unit is moved to another car.
Maybe the power off will be also helped, because after a full restart this handshaking should take place again.
But I think a second update in RUN mode is much easier thing. And it really solved this issue. Hopefully!Thanks for Your help and kindness here!
Just some questions to You as experienced users:
Are there any hidden features in uconnect?
How can I check the version of uconnect without update? -
Please, one thing! Avoid writing in a language different than english or german.Everyone here should be able to read the posts in this Forum.If you want to write in your mother language, feel free to do so via PM.Thanks for your understanding!
For sure, it will. When i downloaded an update on my Jeep, some instruktions came with it. There was written, that the update may be done only in RUN mode! So I thought this is known and I did not ask for it. -
I did not realizied the differences between the two modes, until now.
Anyway, "the cow is off the ice", as we say in Germany.
Have fun with your new Freemont. -
Thanks! -
hängt nun "Telefon" mit der Meldung "Freisprechanlage lädt".
Hatte das Problem schon 2012 und 2013. Hab damals 2 mal neues Bluetooth-Modul bekommen.
An der Hardware liegt es diesmal aber (erst Mal) nicht, weil das Problem ja nun definitiv erst wieder da ist, seit dem neue Softwrae Version mit der Datei "CTPMY12.KWI" drauf ist.Hat jemand einen Link, wo ich alte 2012er Versionen runter laden kann?
NEVER CHANGE A RUNNINHG SYSTEM!!!!!
Viele Grüße aus Berlin
Andreas
